CJK
@RoaringFork — sooo how do we solve this and stop sucking chum into our turbos??
The majority of the crankcase pressure is created by blow by, for any flow circumstance. The difference is where the suction to evacuate the pressure is coming from…Agree, thank you for the explanation @RoaringFork . The crankcase pressure in this pic is being created by the blowbys from the combustion chambers, yes?
I also copied and do this.This is a related thread on the same topic, but for the supercharger:
PCV System with the TRD Supercharger
I'm putting in a supercharger and I came across this thread: PCV 101 for Forced Induction 80's Basically, it suggests that the PCV routing should be changed from the TRD instructions so that the PCV hose moves from the intake manifold to the throttle body adapter pre-supercharger...forum.ih8mud.com
Great find and totally makes sense.This is a related thread on the same topic, but for the supercharger:
Great find and totally makes sense. Rather than installing a second check-valve on PCV line at manifold, I'll cap off manifold and move the PCV line from manifold to the intake tube with an OCC inline.
If we were sticking with recreating the stock system, it seems to me that breather vent hose belongs hooked up to intake between air filter and pre-turbo breather tube (now used for PCV)
Ah, yes. So if we were to hook the PCV to Air intake (pre-turbo), it will always be under vacuum and thus gases can always vent there. I’d be concerned of too much vacuum in the crankcase under full boost as the crankcase would always be trying to equalize pressure with intake (vacuum).I’m having trouble picturing what you’re describing?
“cap off manifold and move the PCV line to the intake tube”
so both PCV and breather hoses to intake tube? Or eliminate breather hose? How about a visual?
the theory behind 2 hoses is the gasses will always have a source of suction to evacuate: to the manifold when vacuum is present there, or the intake tube when no vac in manifold. Is the vacuum required for proper venting? Probably… so going to 1 hose or only using one source of suction may be an issue.
the biggest difference in the PCV from S/C to turbo is: the location of the throttle valve. S/C: throttle valve before charger, turbo: throttle valve after charger. (Manifold)Vacuum starts at the throttle valve(blue in pic below), boost starts at the charger(yellow). Plumbing the PCV hose to the “post throttle valve, pre charger” port on the t-body as described in the linked thread, the system would operate the same as where it is installed in OEM configuration… because, the port on the t-body is pressurized on with the turbo set up, but is only a source of vacuum on the S/C set up…
this is all correct1) vent to PCV-manifold when manifold pressure < 0 PSI with OCC#1 trapping goop
2) vent to air intake when manifold pressure >= 0 PSI with OCC#2 trapping goop
^ that is super clean install, thanks for sharing. So, you have zero oil puddle in the compressor housing after this mod? Could you show us a pic of it opened up, when you get a chance, that is. Thank you for the time.
Where did you buy the catch cans, if I may? Given that these are simply vac hoses, wonder if one could get away with more, thin wall hoses for less "beefy" look and better routing around the firewall? Although lengths of hoses may contribute to the amount of suction, perhaps and not a good idea.
For what it’s worth, here are two Radium catch cans plumbed. I have probably 2000 miles on them now I’m this configuration. A simple L bracket just stands on an empty fender bolt, and if you whistle out the holes on the Radium bracket provided they actually line up to the Charcoal canister studs.
These are Radium Engineering cans, same as what CJK just ordered up. I’m on the road, currently Utah, but will check for oil pooling when I get a sec and report back. Based on this discussion I may swap the hoses on the passenger can, though Radium’s instructions say you can plumb them either direction.
the absurd amount of hose under the hood bothers me too, and I’m curious how the length of hose affects vacuum etc, but I was in a rush to get these in place after having sonic cleaned the intake. I’ve probably collected 1/4 cup of oil between the two so far. More in the PCV can, but probably 70/30.
