Are you hung over, or just dilberately being a twàt?What’s your question? That you have to wait for a bit to get them? Boo who.
I just bought a new OEM fusible link from Partsouq last week and got it via FedEx two days ago.shortage and maybe the NLA of the fusible links from Toyota
The fusible link IS NOT NLA.
Stop making s*** up.
I like the idea of resetable or more easily replaceable units.I do not mind waiting, the idea behind the post was to suggest a replacement, get everyone’s idea on it.
Guys the fusible links are NOT obsolete. Only a current National backorder but they are trickling in. I have 24 arriving today. I have 13 arriving next week. I have an LDO of 100 arriving 4/4 and another order of 60 end of March.
The current availability of these might kinda sorta be my fault![]()
Yes. The OEM alternator is an 80 amp unit. The associated wiring was based on that amperage rating. If you're installing a 150 amp unit, you're now potentially 95% over original intended capacity. That's a fire waiting to happen.If AM1, AM2 are kept at stock rating (no reason to change them), and you were to increase alternator output, is there anything else you'd change in relation to increased alternator output?
Cabling going to main fuse box?
At last someone who understands the potential of a fire when upgrading an alternator! The BS I have seen after an alternator upgrade really pisses me off. Quotes like "I will never run my battery down enough to need the full output of the alternator." or "I might upgrade the cabling if I fit a winch." So many people ask advice about this or that upgrade (not just alternators) and then do something completely different and complain that something does not work.Yes. The OEM alternator is an 80 amp unit. The associated wiring was based on that amperage rating. If you're installing a 150 amp unit, you're now potentially 95% over original intended capacity. That's a fire waiting to happen.
Care must be taken whenever changing major components like this. Proper gauge wire, proper terminal lugs, proper crimping/soldering all play a part in the system.
This is not the area to cut corners.
I dumped the FL's years ago, they are more trouble than they are worth as the vehicle ages, I fitted a fuse box on the inner wing, job done! And as precautionary measure I have a 50 amp breaker on the electric engine cooling fan, and cube fuses on my positive terminals due the position of the cable run for my dual batteries.
Regards
Dave
partsouq ftw
24 in stock, might as well buy them all if you're worried about it
Can get stuff from them faster than most in the US
OK, Dave climbs down from his soapbox thinking about his blood pressure.
Regards
Dave
