Windshield Replacement (3 Viewers)
North of Tulsa
Just removed the broken windshield glass with the frame off the vehicle. I have a few questions:
1. Although it's broken it's still in one piece. Should I keep it for a template?
2. What can I expect to pay for a custom cut piece?
3. The gasket is still semi-soft. Any issues in reusing it?
Also, check out this sticker that was on the broken factory Toyota windshield. Was that a sticker on a new vehicle or a replacement windshield? just curious...
our local toyota dealer had a replacemnt windshield. Think it was 120 IIRC
Thanks for the responses. Got one cut from local glass shop $169.
Does anyone have hands-on experience installing the windshield with an aftermarket gasket vs a Toyota gasket? (CCOT has the reproduction for half cost of the factory one.)
That Made in Japan sticker is on my driver side door window. I assume it was on there from the factory. I bought a Toyota windshield and re-used my gasket when I replaced mine.
I had a replacement windshield cut for mine a couple years ago. I was happy with it until last week when I tried to remove the glass for blasting and paint. I got a little excited on how easily it was coming out and broke the glass. That was obviously my fault, but the concerning part is how it broke- lots of really sharp shards. I'm going to pony up for a laminated windshield when its time to replace it. I would shutter to think what had happened in an accident or good sized rock had hit the windshield at highway speed. Just my two cents.
Yes, that's crazy dangerous. Around here I'm pretty sure laminated glass is a legal requirement. I'm surprised whoever cut it for you didn't insist on that.
Was the glass you had cut not laminated?
Obviously, I need to do more research. I had a couple irons in fire at the time and assumed the pros at the glass shop would steer me right. From the recent research I did I was under the assumption that laminated glass cant be cut. Is this not true?
I've read that tempered glass can't be cut but laminated safety glass can.
This must of been what I was thinking of, sorry for the confusion. Called around for a local shop an he said he could do it for under $200. Thanks for setting me straight on this issue- I was going to order it from Cruiser Corps for ~$250.
