what is the size screw for the pre-tapped OEM holes (11) that go across the top of the fj40 windshield frame? I bought a Tiger channel for my SOR family top and the screws are too thin as they're made for a Jeep likely. Thanks!
Toyota lists currently:Reviving an old thread but can someone provide the length and head type? Or better yet a OEM part number if still available. I’m getting ready to put my real steel bows on. Thanks
So I just ordered the one of the one you prefer. I’ll be the guinea pig and let you know if it clears are not.Toyota lists currently:
93315-16014 - Qty 2
91611-G0612 - Qty 5
-16014 is a JIS philips head
-G0612 is a hex, your call on what you use.
Both should be M6x1.0 as the -G0612 is the supercession from the original 91611-40612 part number.....which is a Tensile strength 4, M6 and 12mm length screw.
Another option which I prefer (but would need to verify flat washer clears is 91651-40612, which is a hex head, captured lock/flat washer in a 12mm length.
