- Thread starter
- #21
Okay:
1st test I did (fuse out touching both pins with prob, IG key on sw activated) show switch not actively closing circuit RL. Also that drivers working window switch (FL) did activate it's fuse port.
2nd test with fuse in, IG off and Switch inactive. l confirm 12 volts power to both fuse FL & RL.
3rd test touching one fusesports pin at a time w/ (+) prob and ground (-) prob to body, w/IG off and Switch inactive. Showed both RL (inop window ds rear) & FL (working ds window) have 12 volts of power at lower pins, non at top pins.
So power to both FL & RL fuse ports is hot at 12V.
But switches (master or slave) of inop window, not activating fuse port RL with 12V. WHY????????????
