Simple test.. pull the front driveshaft. Lock the center and see what happens
Some metal on the plug is normal. Especially the shavings you found. No large chunks are good. I would not worry about the transfer case at all. Fresh fluids and fix the front diff.Still, the metal on the drain plug? Would you ignore it? I want to open and inspect the transfer case.
I’ve seen it happen after a few days of romping out in sand and rocks. The t case was fine, but this was also on a 4Runner TCase. I expect the LC case is stronger.No I'm on the right parts- the front diff is coming out. I don't want to look back and say man if I just would have....
Metal shavings are normal? In 1500 miles? I just changed all fluids 1500 ago, that is why this metal concerns me.
Thoughts?
Well I cannot say what exactly caused this, when you wheel you break. But for sure saved someone. and I would do it again.
Start with the front diff, it’s clearly broken (if you’ve ruled out flanges), but there’s no reason to open the transfer case unless it’s really needed. So you open it up and don’t see any significant damage? What are you going to replace? Just the proper seals to seal the case back up? At that point to me you’ve just added a touch of human error to a part that was probably ok, potentaillly leading to future leaks, issues, etc. But the same could be said for leaving it alone.
How often are your change intervals on your diffs/tcase? Proper fluid?
Curious if you were you winching from a stationary point or winching/pulling at the same time? In the shots it looks like you're using a strap as a winchline extension. Did you use a kinetic snatch strap or a tow strap to recover the other vehicle?
winching/pulling- I actually dug out a lot and then made the two idiots dig even more, then we dug more. I don't like to yank ( I know it works) but I like to be easy on equipment. While backing up I winched in a little, stopped, and dug, and re-positioned and repeat. A couple of times I was spinning the wheels a little, But I really try not to. But I may have been broken before hand in the snow drift, not sure.
Do you guys recommend a different method- I am all ears. I have only winched out a dozen or so people- I am no expert
Yup, blew the front diff of an old ifs Toyota pickup that way.
If your going to take the tcase apart it’d be worth putting in a reduction gear set or if you want to run part time hubs, a solid carrier.
