Pre '68 F engines used siamesed exhaust ports and a deep "bathtub" style combustion chamber. They're pretty much on their own so far as interchanginf anything.
From then until '72 the F engine used a flattop piston and a closed combustion chamber.
'73 and '74 F engines used an open combustion chamber and a very small dome on the piston.
'75-'80 US variant 2Fs used an open chamber and a domed piston.
'81 and later 2Fs used a closed chamber and a flat top piston.
A '73-'74 F head will be a bolt on swap to any of the 2F, producing more compression on the '75-'80 blocks.
A pre '73 F head will swap to the later 2F engines once the rocker arm oiling is addressed. There will be piston/head interference on the early 2Fs
You can install an early 2F head on a late 2F engine. You will loose compression.
You can install any 2F head on the pre-'73 F engines. Again, you will loose compression, especially if you install an early 2F head with the open chamber.
Mark...
