swamp-thing
I see the part numbers are different between the years...:
1993-1994 FZJ80 Brass 3 row Radiator: 16400-66040 ( seems like it will fit '95-'97 also)
1995-1997 FZJ80 2 row aluminum radiator: 16400-66081
BUT I can't determine via search if the later rads are able to be used in the earlier 1fz-fe models:
Story:
The OEM rad on my 93 80 series has a leak on the seam at the top. It's the earlier brass type.
I have a low mile radiator from a 95 that I parted out, it was holding and cooling just fine when pulled.
Can I pop this 95 radiator into my 93?
I see lots of chatter about what to replace OEM rads with, but my question is about backwards compatibility....
Thanks In Advance.
Story:
Thanks In Advance.
