- Thread starter
- #21
Went to test drive a monster 1997 on M/T tires yesterday and wow this is a different beast, I imagine the rowdy tires and 3.5" lift were the contributing factors, need to find a less intense example, maybe with "only" AT tires
I agree about all said with loose / poor maintained components.Lift without proper setup (caster correction, etc.), loose suspension components (bushings, etc.), loose steering components (frame crack, loose box, worn trunion bearings, loose wheel bearings, etc.) would all be no surprise on one of these unless it was well looked after. Even a stock height / stock tire size 80 that doesn't have tight susp/steering is a handful and can be pretty sketchy at highway speeds with a tendency to follow seams/ruts and bump steer etc.
The rig you looked at may have been dialed but I would expect at least a few issues in the above areas and be pleasantly surprised if they aren't present on rigs you review.
