Hi All:
When I installed the Wilwood proportioning valve in the rear circuit of my FJ40's brake system I used the metric to NPT adapters that
Summit Racing sells.
DSRTRDR (aka Claudia) had mentioned in her ROTW using these pieces - below is her PM response to my query for part numbers.
Regards,
Alan
DSRTRDR wrote:
Re: Brake Fittings.
Here goes: Basically, we went from metric to National Pipe Thread (which is what my Wilwood prop valve came with for 3/16 standard brake line thickness, but you want to connect to Toyota brake line metric) via AN, meaning each side of the prop valve has an adaptor NPT to AN, and the AN fittings adapt tp metric. Depending on your space, you might want to think about getting the NPT to AN fittings angled (like 90 degress); race car shops will have those or can source them for you. So from the Master cylinder [10mm - AN] connects to [AN - NPT] in the prop. valve, the out the prop. valve [NPT - AN[ connects to [AN - 10mm], anything in [] is an adapter fitting. Just need to make sure what the thread is on your prop. valve.
here are the numbers I used to purchase (the race shop I went to locally sourced one of them from a different supplier, but they were able to do so with these numbers):
you need two of the 1/8 NPT male to -3AN female adapters (EAR 916103 ERL stands for Earl's)
you need one of male 10mm to male -3AN
(EAR 592032 ERL) this goes into the master cylinder
you need one of 10mm female inverted flare to -3AN male
(EAR 989538 Earl's) this connects the prop. valve to the brake line.
We found them via Summit catalog website that connects to Earl's, but it took some doing since the pictures are sooo small (that's why we went to the local shop to confirm, otherwise you might be able to order on-line).
Cost is approximately $8 each. No flaring (we figured it needed to much training on our part), and we were able to keep the brake fluid mess to a minimum. We put teflon tape on the threads, pipe sealant works as well (our hardware store didn't have).
Hope this helps. You'll figue it out as soon as you see the fittings.
