NAPA has the speedo cables too,
Speedometer Cable
$22.00 is cheap
x2 on installing it in the cluster first, then routing it so there are not any harsh curves,
Looks like they are still available from NAPA for about $20 USD
Speedometer Cable
$22.00 is cheap
It’s kinking behind the dash as you put the cluster back in.
Pull the excess cable through the fire wall as you place the cluster back in. This will pull the kink out as you refit.
You can also notch the pedal bucket to make life easier forever more.
