- Thread starter
- #41
@brooksfj60 you MIGHT consider carefully locating and cutting tight slots to fit the outboard seatbelt anchor ends thru- y'know, the ones at the base of the Bpillar...it could be carefully located and cut, then the slot melted with a hot soldering iron, as suggested by @reevesci . Also, a slot tightly cut to fit the mat "around" the drivers dash support would also be a good addendum to what I've depicted. I cut out for the throttle stop- dont. fit it, fit it, fit it, then cut it less than you think and repeat. sand bags or water bags would help greatly to sink it to the floor, in order to figure out where it will eventually lie before you decide where to cut... The front mat is located best by the seat risers front and rear, and the shifter tunnel is a tricky summa gub...if you do how I did, once you get it to lay out and decide where it needs to be cut, cut it, and fit it, you'll start by laying it in, then slipping the boots under it and stuffing them thru the top of it and bolting them down to the tunnel reaching up from the doors, then finish laying it in...I do think I like the seatbelt receiver, seat slider mounts, and backseat mounts all bolted thru the vinyl, whereas the outboard seatbelt anchors should be bolted below the vinyl, in order to keep things from building up in the valley of the door well...NOW, an alternative approach would be to cut and slot everything to slide over/around the fixtures so it could be removed for easy washing. if you look at - so soory J for bringing these guys into it- $$$$ORs cut and sewn carpet, they show how a guy could cut up the vinyl to "lay in" but I don't think it would work well for those of us who have important people operating and riding in them daily, as it would leave too much void. a guy would be trading ease of removal for cleaning for a potential NEED TO REMOVE TO CLEAN, as a byproduct of how easy it was to remove...jumping jimmeny cricket on a pogo stick...I've just pulled a classic @Delancy
