DanS HJ-45
- Thread starter
- #41
What's going on?
I like where this is going...
Since you love rebuilding FF's, have you looked into finding a inner axle seal that could be described as a hd seal, like marlins for the front?
I have only used the oems, but even with good diff breather,some fluid passes by.
I haven't. I don't see how much more heavy a seal could fit in there, since it's not a big space between the axle shaft and the inside diameter of the spindle. I expect that most seal problems there are caused by a rough surface on the axle shaft, so if I was really concerned with it I would put a speedy sleeve on it and see how that worked.
Need more updates & pics![]()
Yes need more updates
I agree. I do need more updates and pics.
Unfortunately, I haven't worked on it a single minute for the past few months. Something, something.... work too hard......
Likely starting in January I should have some time to work on cruisers again.
I did just spend a week with Dad's HJ-61, and it sure made me want to get the 1HZ into the 60 so I can have mine instead. Then I won't feel bad getting it dirty.
Dan
