Update!
If you recall, I had two issues: ride was overly harsh, and the 40 was too high... I couldn't get it into the garage at work!
Parallel thread
NEWBIE Question! Rough Country Systems and Shackle Angles...
I took two steps:
- Installed shorter shackles
- Removed the second from the bottom leaf on the rear springs
Installing the shorter shackles shaved about 1.25" of overall height (shackles were 2.5" shorter)... this was still not enough to access the parking garage. Removing the leaves did the trick. The truck is now about 2-2.25" lower, and the ride is
noticeably smoother too!
The previous set of shackles were by the way way too tight, which of course contributed to the harsh ride. The angle of those shackles were just about 90 degrees all around... you can see in the picture below how the front shackles show a bit more of an angle now. The rear shackles are still ~90 degrees, but that doesn't bother me anymore... the ride is now good and smooth!
I for one think that the overall stance is nicer too...
Thanks to all of you that helped!
