I have a 86 BJ74 and am unhappy with the rear suspension. My current rear spring cannot handle the load/use of my car. I was finding while driving on the road or on bumpy tracks quickly the rear suspension would compress nearly to the bump stop causing the tyres to hit the outer guard lip even with the 1'' body lift. This is worst on the drivers side and only when running 35'' tyres. Current rear spings were bought second hand, but do not look that old no idea of their life before me. They are single stage 9 leaf EFS 50mm lift springs apparently rated to 300kg contant load in a 60 series. See this link http://www.efs4wd.com.au/Cataloguehtmlinfo/Toyota/25b.pdf
I am going to fit ARB OME Dakar rear leaf springs, but I have a few choices that I would like opinions on.
-CS017RA/B - Medium spring - 70 series listing - 50mm lift
-CS004RA/B - Heavy spring, Constant 200kg - 70 series listing - 75mm lift when load with 200kg, 6 leaves + 2 overload
-CS005RA/B - Heavy spring, Constant 200kg - 60 series listing - 75mm lift when load with 200kg, 7 leaves + 2 overload
When I spoke with ARB they said the 200kg is a standard car with 200kg in the back, be it gear or peope leaving 75mm lift loaded.
My car has no rear seats, instead a timber draw system, itself about 50kg empty on this is a 60L fridge which would be 50kg full, a steel rear bumper replacing the stock unit, about 30kg. I carry a 35'' beadlocked spare tyre and high lift jack on the rear door, 40kg. In the draw system are tools, oil, engine water, beer and food. Probably about 60kg worth when fully packed. Outside the draw system I carry 20L water 20kg, spare parts, about 30kg worth then my camping gear and clothing. All this weight is pretty much straight above or behind the rear axel. Then include two passengers at 200kg up front with some stuff.
Totaling: 50+50+30+40+60+20+30 = 280kg + camping gear (tent chair, clothes, utensiles) and passengers. This also excludes fuel which will be about 120kg.
Does anyone have any experience with the above springs and a loaded car? Just typing this thread out has made me think I should just go all the way too the CS005RA/B 60 series springs.
This is how it sits on 33''s without the rear draws and crap installed.
