Where to buy the tensioner block?
San Diego, CA
So I am going through my rig, replacing water pump and a lot of cleaning up. During this process I noticed that my alternator tensioner 'block' was stripped. I've looked at couple places and haven't found a replacement. Any one know where I can buy a replacement?
2mbb
WC, CA
Not sure what the difference is between the two versions listed, but I'm sure the company owner will post up soon:
@ToyotaMatt
Spike Strip
Goblin Mode Activated
Lost Angeles
They both work and they're just different ways to solve the same problem using OE Toyota parts. I used the one with the square block as it's closer to what was stock on 60s.
Matt is the only place that sells the kits.
The other one works for Alternators, too.
Vermont
Could you just drill the bad threads out and put a washer and nut on the end of the threaded rod?
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
hi matt here
You absolutely NEED Kit #2 , it has that Square block with the Female threads that Strip all the time
please see this Link here :
Please let me know how i can help :)
i have the correct slider block for you with the threads going long ways like the below Photo too
i hope these updated photos help explain in detail what all comes in my KUSTOM All Toyota Genuine parts Repair and Restore Tension Kits
please let me know how i can further help
if your SMOG pump tension block is bad too , i can help also
matt
