Builds Where it all began... an FJ62 story (7 Viewers)
Then after getting that piece fitted, I had some momentum and wanted to get the middle piece in (last one I need to complete before it goes to @cruisermatt ) and after laying the old on top of the new, I questioned whether or not I needed that rear heater… I live in the South.
Gonna look up what hoses I need to do this cleaner under the hood but for this afternoon, I just wanted the heater out. Gonna stick some bolts in the hoses under the truck with a little RTV and clamps and deal with the rest tomorrow…
we've welded that hole for the heater shut on a few 60's.
We're prob gonna do like we did on my FJ80, and just cut a small patch out of some aluminum sheeting scraps we have and screw it down with a bit of RTV around the edges before covering it up with carpet, never to be seen again!
And just like that.
✅ Rear carpet put back
✅ Rear heater and lines capped off til I have a moment to delete from under the hood
✅ Aluminum scrap plate cut and RTV’d to the hole left from the rear heater
✅ Tailgate carpet finished… my staples were too long so I used glue on the edges too and it turned out fine
✅ Laid second row carpet in, gonna find the anchor points, get some openings in the carpet, trim the sides, get the rear door sills in, and get the rest of the rear seat in…
If ANYONE ever says that changing the carpet to new carpet (especially when such a great product from @dnp is available at a great price) doesn’t make things feel and smell and look 10x better than your “carpet in great shape”… well, they lying.
Second Land Cruiser to replace the carpet and it just makes such a huge difference in my opinion… and I had great carpet with no smells or rips (which we be up for sale if someone needs it!) but it just makes such a huge difference.
✅ 2nd row and rear carpet installed with the trim back in place… front row getting done @cruisermatt ’s shop with the H55
Thanks for the positive comments. Yeah, we worked really hard to make this carpet as "correct" to OEM as possible (regarding, fit, finish, texture, and color), and there's really nothing you can do to the interior that's more transformative than this carpet! It's truly astounding! And you're also spot on about the OEM carpet. It's notorious for fading out over time, due to heat and UV exposure, so while it might look to be in "excellent shape," it may actually be a completely different color than it would have been when new.
The shipper and I have a deal that he’ll come pick the truck up sometime within a given period of time based on when he has space. I was expecting a couple days notice, maybe 24 hrs… I got 30 minutes. Luckily the interior is basically done (for now) and the truck is ready to go to @cruisermatt because it’ll be there tomorrow morning :)
One snag that was left unfinished… since we deleted the rear heater and just cut/plugged the lines under the truck temporarily until we make a more permanent/elegant under-hood heater-hose rerouting/capping… I believe I lost just enough coolant, or more importantly introduced just enough air into the system to affect the cooling.
I ran the truck for 5-7 minutes, while getting it on the trailer and the temp gauge started to move very high very quickly. I’m pretty sure just burping the system is the remedy for that, overheating hasn’t been an issue in my ownership AT ALL. Frankly, I wasn’t even sure the temp gauge was working (never gets above 1/3rd on the gauge, ever).
I’ll be doing some work here, maybe working on my center console, getting some lighting stuff together, getting Geoloanders mounted… but for the next couple week at least, it’ll be getting a tan in Winter Park, FL.
The ‘ol girl may be going under the knife hopefully at the end of this week… once a different, similar build for another dude in Atlanta gets finished.
Here’s a pic of the h55 with the rebuilt split case and 10% reduction gears…
Overdrive, not reduction :)
driveshafts are shortened/lengthened, just finishing up another FJ62 and then this one is on deck :cool:
Working on a new scratch-built H55f crossmember kit for these swaps as the pricing of used crossmembers has went unreasonably high IMO.
Time to start getting some more updates in this thread… @cruisermatt has my girl on the lift and she’s getting that knee-replacement that she so desperately needs. Side Note: If I could get 2+ inches of lift for $2K on my legs, I’d be first in line.
  • Front and Rear OME springs IN
  • Next up, caster shims and shock bushings to button up the suspension
  • Identified a couple of “while we’re in there” items - Need to replace axle-to-frame hose with a longer one, and source some clips for the short brake hose that comes from the axle to the caliper
I’m stoked we’re making progress and looking forward to more next week!
PS When she gets back home, I have one of those attachments for the pressure washer that has wheels and shoots UP… that underside will get cleaned and fluid-filmed, not that we have salt in the state of GA, but just to keep things lookin svelt and preserve that frame from any rusty intentions…
This lift is our special flavor blend of OME/Bilstein that rides great and has perfect level stance. :cool:
Going to add lists of items for the work once the 62 gets back from Cruiser Matt's and then all of the items that are going into the build at the shop...
Parts that are waiting here with me...
Windshield Wiper mod (4runner 2 x left hand wipers)
8524790A01CAP
SHIELD; WINDSHIELD WIPER PIVOT, NO. 2.
Rick Hendrick Toyota2
8522235091Windshield Wiper Blade (Left, Front) - Left Hand SideRick Hendrick Toyota2
9017908113Windshield Wiper Arm Nut (Front)Rick Hendrick Toyota2
8519212800CAP; COVER
FRONT WIPER ARM HEAD; WINDSHIELD WIPER ARM
8522135080Windshield Wiper Arm (Left, Front)Rick Hendrick Toyota2
Wheels/Tires
Yokohama Geolandar M/T G003 255/85/16SimpleTire5
42601602620370-Series WheelsRick Hendrick Toyota5
Sidemarker Lights from VintageTEQParts.com
FJ60 FJ62 NEW PURE JIS YELLOW LUMIN COLOR TONE TECHNOLEGY ( Light Emitting Diodes ) Equipped Type , Set of NEW OEM Front AMBER " KUSTOM KOITO " Side marker Lights / Lamps Kit NEW TOYOTA Genuine Parts SIDE Marker FJ60, FJ62 1981-1990 × 1VintageTEqParts.com1
Roof Rack
Yakima 1A Raingutter Towers x 4ih8mud member
Tune Up stuff
90919-01064Spark PlugCruiserMatt's Off Road6
90919-21451Spark Plug WireCruiserMatt's Off Road1
19101-61240Distributor CapCruiserMatt's Off Road1
19102-61240Distributor RotorCruiserMatt's Off Road1
Front Seatbelt female plastic covers - Not sure if I'm gonna be able to fit these...
Seatbelt Plastic SleevesSeatbeltplanet.com2
Daniel Stern Lighting upgrade
Cibie 165mm H4 headlampDaniel Stern Lighting2
Koito 165mm H1 headlampDaniel Stern Lighting2
Tungsram H4 +120 bulb/pairDaniel Stern Lighting1
Tungsram H1 +120 bulb/pairDaniel Stern Lighting1
Reverse lamp upgrade bulbDaniel Stern Lighting2
Brake light upgrade bulbDaniel Stern Lighting2
Toyota FJ62 4-lamp harnessDaniel Stern Lighting1
Side marker upgrade bulbDaniel Stern Lighting4
New door mounted armrests from One Stone Armrests
One Stone ArmrestsOne Stone Armrests1
Underhood insulator and associated bits and pieces
904670801183ClipRick Hendrick Toyota9
5338460030Bumper hood rearRick Hendrick Toyota4
9046709014Clip for Hood InsulatorRick Hendrick Toyota19
5334190A00Insulator, Hoodrick Hendrick Toyota1
And the parts for the work @cruisermatt 's shop...
Basically it's for a lift, 5-speed conversion (with associated parts), and items while we're in there... which so far are clips/pigtails but we'll see how that goes... there may be more. It's a lot of parts, most new, some re-purposed/rebuilt, but I'm very glad that these things are being replaced/sourced by @cruisermatt I know my abilities and I know my shortcomings, and sourcing/installing all of this would have been a task that I just don't have the expertise or time to do, and IMHO is better left to the experts.
H55F Complete AssemblyCruiserMatt's Off Road1
OEM Clutch ForkCruiserMatt's Off Road1
OEM Throwout BearingCruiserMatt's Off Road1
AISIN Clutch MasterCruiserMatt's Off Road1
AISIN Clutch SlaveCruiserMatt's Off Road1
OEM Clutch HoseCruiserMatt's Off Road1
OEM Fork BootCruiserMatt's Off Road1
OEM Transmission BoltsCruiserMatt's Off Road4
OEM Transmission MountCruiserMatt's Off Road1
AISIN Clutch KitCruiserMatt's Off Road1
OEM Clutch Fork ClipsCruiserMatt's Off Road3
Vacuum Diaphragm Rebuild KitCruiserMatt's Off Road1
Transfer Case Rebuild KitCruiserMatt's Off Road1
Long Spline Input GearCruiserMatt's Off Road1
Bell HousingCruiserMatt's Off Road1
Pedal BucketCruiserMatt's Off Road1
Resurfaced FlywheelCruiserMatt's Off Road1
Matt Wire Harness (Auto to Manual Conversion)CruiserMatt's Off Road1
OME Leaf Springs + Bilstein Shocks with all associated HardwareCruiserMatt's Off Road1
High Range GearsCruiserMatt's Off Road1
Front and Rear Driveshaft Modification + New U-jointsCruiserMatt's Off Road1
Labor Transfer Case RebuildCruiserMatt's Off Road1
T-case to Transmission BoltsCruiserMatt's Off Road4
T-case to Transmission BoltsCruiserMatt's Off Road3
5-speed shift knobCruiserMatt's Off Road1
Pressure Plate BoltsCruiserMatt's Off Road6
Brake and Clutch PadsCruiserMatt's Off Road2
Brake HosesCruiserMatt's Off Road2
Brake Hose ClipsCruiserMatt's Off Road2
Custom Clutch Slave Line FabricationCruiserMatt's Off Road1
Labor Suspension InstallCruiserMatt's Off Road7
Spare tire in first pic looks original...30+ year old OEM fossil. What were those, Dunlops?
Good question. I don’t know, never even got around to looking at it before I sent it to FL for the work. But yes it’s probably as old as the truck!
Yeah, old original spare.
Love this thread. Happy to see a good shop like Matt’s working on it.
I’ll be moving on my 62 H55F swap this weekend. Finally. Still beating @Skniper though.
