I use up like a quart every 750 miles or so?.....will just keep running it and add as needed. Still runs good
That's a lot of oil consumption. Is it leaking or consuming the oil?
Wow, thanks for all the input!
This question has come up b/c we are in the shop now fixing a multitude of oil leaks and it was suggested to pull the head and have it machined based on our mileage. I choose to skip that b/c it runs well and I didn't have the extra cash. I guess I'm willing to wait until the headgasket goes.
Overall, the previous owner and my wife used it primarily as a daily driver.
The bottom ends hold together very well on these motors. The top end and seals seems to take the most beating. When the HG went on my 94 at roughly 200k miles I decided to tear down the entire motor. With the exception of the #6 cylinder having water staining from the HG leak, the bottom end could have almost been mistaken for new. Even the bores were pristine with factory cross hatching very evident.
Anecdotally I think its wise to at least consider the HG at 250k. I did mine at 226k as preventative and the gasket around #6 was indicating a future failure. That having been said, when I got it the cooling system was hoop-a-jooped and it had probably been run hot for a while before I ran it hot. Heat kills the gaskets on these things. When the head came off the rest of the engine was in good shape but most of the injectors were in need of rebuild at that time. In terms of a complete rebuild, I don't think thats necessary until it is, but other engine items may need attention before that. I would at least replace your radiator if you don't know the last time it was replaced. They accumulate crud and fill up or the plastic top caps crack and explodes as failure modes.
Glad I came across this posting. I picked up a 97 triple locked from south carolina with 360K miles on it fairly cheap a couple of weeks ago, my first TLC. Runs pretty good and doesn't seem to be leaking oil but oil pressure comes and goes. While driving the pressure is fine but sitting at a light at low idle it drops to just above the red line. Have been contemplating if it needs a full rebuild or just get the head and gasket done on it. What things should I be checking to determine if this is a rebuild type situation or just a head and gasket one. From what I understand this has never had any major engine work done to it at all, doubt the HG has even been done.
What oil filter? I had low pressure with a bosch and went back to a toyota filter and problem solved.Glad I came across this posting. I picked up a 97 triple locked from south carolina with 360K miles on it fairly cheap a couple of weeks ago, my first TLC. Runs pretty good and doesn't seem to be leaking oil but oil pressure comes and goes. While driving the pressure is fine but sitting at a light at low idle it drops to just above the red line. Have been contemplating if it needs a full rebuild or just get the head and gasket done on it. What things should I be checking to determine if this is a rebuild type situation or just a head and gasket one. From what I understand this has never had any major engine work done to it at all, doubt the HG has even been done.
It all depends on what you are willing to put put with. IK have had high mileage engines that had one or two dead cylinders and would use a quart of oil every tank of gas. I don’t put up with that any more now that Iam no longer poor white trash.
