Will Van
GOLD Star
Hey guys! I spend most of my time over in the 80 series section, but I have a question for you 60 series guys.
I just bought a set of Wheel Vintiques Series 12 "Smoothies" for my '93 FZJ80. Nobody really runs this wheel in the 80 section, but I know a lot of 60 series guys run the smoothies. I noticed when swapping from the 80 series OEM aluminum wheel, to the smoothies, the backside of the wheels are different.
On the OEM aluminum wheel, the back face of the wheel is machined flat to sit flat up against the face of the wheel hub.
On the Wheel Vintiques wheel, the backside of the wheel is not flat, and is slightly concave. Essentially, only a small portion of the wheel is actually touching the face of the hub. Is this a problem? Have any of you 60 guys had an issue with the Wheel Vintiques Smoothies or other steel wheels?
You can get a better angle from the front of the wheel. Basically the "ring" where the lug nuts bolt to the studs, isn't sitting flush up against the face of the wheel hub.
I know tons of guys run steelies, including Toyota spare wheels. Are those steelies machined flat and sitting flush against the face of the wheel hub?
Thanks in advance!
Thanks in advance!
