Whats this Coil
landcrusher909
Athlete/Race truck driver/Hobbyist
GOLD Star
Southern Calif.
Just picked up this motor and could use some help making sence of this coil Thanks
Doesn't look like a Toyota part at all!!
I think the coil does, minus it has been painted, maybe not the other junk, I have not seen one exactly like that before
Thanks has anyone had any luck with these ? If its worth keeping I might transfer it to one of the other motors
It's a 75-76 "semi-electronic" coil/ignitor with ballast resistor, normally triggered by points. Mine always worked well.
The best feature, is that if the ignitor portion failed, you could bypass it and run the coil just with the points. That was a good limp home option and it was even explained in the manual!
Anyway, if your going to all that trouble, it's worth it to convert to the full electronic set up from an FJ60.
I think I have a couple of spares of this one shown if you need one as I no longer use that type.
