nukegoat
Should have bought a Jeep
- Thread starter
- #21
Really? I have a lot of aluminum brake line adapters that seem okConfirm x4, 16mm high-pressure, 17mm low-pressure. Both inverted flares in the box. I am running all -6 on everything except for the return from my remote reservoir to the pump, which is -10. My high pressure side fittings are all Aeroquip JIC high-pressure line and fittings rated for something like 2500 or 2800 psi. Return side are all regular aluminum AN fittings and black nylon hose. Works good except for my pump which is messed up.
The regular aluminum fittings are not rated for more then a few hundred PSI. I used to have a high-pressure side line with the regular aluminum fittings and it worked on the street but as soon as you got on any rocks it would instantly burst.
