Hey @Taco2Cruiser... here is a long thought I was gonna post when there was disagreement over skill vs. getting stuck, etc.
It includes the high center reasoning. See what you think (sorry so wordy)...
I'll have a go at a scenario ANYONE can get stuck in--whether you're mentally challenged (like me
)...or an expert--and why I prefer to have multiple recovery options available. See what u think, @Taco2Cruiser and others.
First: I'm no recovery expert. Not by ANY stretch. But here goes...
California terrain can dramatically change...withing FEET...so that even on a short run, it can be unpredictable. Age-old sliding fault-lines, subduction zones, and former ocean floor deposits...along with dry, but sometimes deceivingly treacherous lake beds, river beds and even swamps can be fiendishly disguised on top as something else. These weird mixtures can pop up in the deserts and even some mountains. The water table can runs in bizarre ways here, meaning oddball areas can carry a lot of moisture for a very long time...right next to bone-dry sand or solid rock.
When out exploring (off-trail or off-road)...you are, by definition, NOT in familiar territory...so while you can sorta know your terrain, hidden stuff can lurk.
First, an example from mountain biking in coastal and inland California.
On a mountain bike... You can be flying down dirt or decomposed granite descent with traction to spare...then suddenly you find a patch of TRUE, FLUFFY, DEEP SAND...then sand/dirt...then all dirt...then solid granite...sandstone...clay...mud...roots...and everything in-between. Or...You can be gliding over sand just fine, and then you hit a patch that hides wet CLAY that's like chocolate pudding--distinctly different without discernible visual warning.
-If you happen to find this in a turn, you can easily lose control even as a skilled rider.
-If you find it in a heavy vehicle? You're going DEEP (again...ask me how I know! haha).
4-Wheel EXPLORING (not on trails/roads):
Sometimes it's fun to just go exploring--meaning you can't know the "trail" because it isn't a trail. In the local deserts near me, you can do that and there aren't always dedicated paths or roads. Some sand lies tightly together forming a nice, firmly-packed base that you can easily ride on top of. -Especially true where sand is near vegetation, and therefore mixed with dirt/organic stuff, and holds together nicely. But nearby, and sometimes without warning, there can be areas that are either suddenly hidden mud just beneath a seemingly solid surface, or true sand (no dirt/organic stuff mixed in) that stays incredibly "fluffy" and bogs super easily. Same with snow.
--Making recovery more "interesting..." -these are often found where there are no recovery anchors.
-No trees...no boulders...or other anchor points.
If you get quickly bogged to where you sink into mud or super-loose sand, be on your belly in less than a second--even without rookie tire spinning your way down deep...so that even aired-down tires have nothing to grab--because belly deep, vehicle weight is off the tires--meaning they don't spread to create more traction.
This could be called a MISTAKE...but it can happen to rookies and veterans alike.
-Poop happens, ya know? You try to avoid it, and try to be smart, but sometimes if you are breaking new ground while exploring (pun intended
), you can't always outsmart hidden "traps."
Anyway... If you end up instantly belly-deep...with tires that have nothing to grab...nowhere to winch from...
...MaxTrax can be helpful. Especially if you have one for each tire, or connect them to create the floatation even aired-down tires failed to adequately create. One helpful thing about Maxtrax or other units is that you don't just create traction under the tire, but a path of traction that can give you the little bit of momentum you need to keep going beyond the track.
Soooo... Options are good in my book.
--Even the dangerous Hi-Lift can be attached to a WHEEL so that instead of lifting the entire vehicle beyond suspension droop to get crud under a tire...you simply compress the suspension to get under there. You can even use one maxtrax as a hi-lift base until you jack up enough to get an entire tax under a tire. By compressing the suspension, you aren't actually lifting the vehicle to get under it. -Just compressing on corner of your suspension at a time.
-An airbag can work to lift the entire side of a truck, but it doesn't compress the suspension like a hi-lift attached to a wheel...so you gotta lift clear past full droop before you get under the tire.
My take is...why not take options along?
-A winch...Maxtrax...hi-lift...
-Snatch and tow straps are always with me too, but only help if there's another vehicle...and sometimes buddies aren't around. Sometimes winches can't be anchored. Even experts can get caught. So options are a good thing in my thinking. Easy to carry this stuff, so why not?
Watch-u-tink, mang?"
