So over the last few weeks every once and awhile my brakes will be hard as rocks and so i thought it was the calipers so today i installed new ones today and bled the system but while bleeding i would pump the brake pedal and it wasn't pushing fluid through the calipers in order to bleed. I just did the trick where you put your foot on the pedal and start the truck and the pedal should give a little and then get firm. Well nothing happened. Even with the truck on i pumped the pedal and it new got firm. Would this be a Booster issue, MC issue or both? I assume this is the original booster. i am going to tru and bleed again in the morning. I am hoping its just air in the lines but i doubt that is the problem.
Jason
Jason
