I'm in the middle of sweating bullets on trying to drill the plug out on mine. I have 5/16x24 allen head plugs and the appropriate brand new tap if I can get the old plug out. It seems to be really well pressed into my head.
Here's where I'm at:
1. I removed all the crap to replace the intake and exhaust manifold due to an exhaust leak. While all that stuff is off, I figured I'd repair the oil galley plug.
2. Starting out, I tried to do it cheap by using a dremel and a small (3/32) drill bit. I drilled a pilot hole, then screwed in a machine screw about 1/16 inch. I tried to pry the plug out and the screw tip broke off in the plug.
3. Next, I used a dremel burr to grind down the screw.
4. Then, I went and bought a right angle attachment for my drill and a Black and Decker reverse thread easy-out bit. I drilled the appropriate pilot hole (5/64), and began screwing in the easy out with a crescent wrench per the directions. The easy out snapped off.
5. Once again, I used the dremel burr to grind down the easy out.
6. I was going to just use a 1/4 inch or 5/16 inch bit and drill the plug out, but even with the right angle attachment, there is not enough room. So, I have replacement heater hoses for my engine (my 3rd project while replacing my manifolds), and may remove the heater hoses that are in the way of replacing the oil galley plug with the head in the truck.
As usual, what many report as a simple 1 hour preventative maintenance job is turning in to a major endeavor for me.
I may be looking at pulling the head, which I really don't want to do. I've got 160,000 miles and the last time I checked my compression, everything was well within spec.
Suggestions?
Suggestions?
