Xpel is what I used a few years ago.
I used 3M.
Do you guys replace this film every few years? Or does it last longer than that?
I used 3M.
I put 3M file over every inch of the truck Except the rear tail/lift gate and the roof behind the sunroof where the roof rack is.Do you guys replace this film every few years? Or does it last longer than that?
Removing the wife’s ppf after 4 or so years was a damn bear. Just came off in thousands of pieces. Too me and the wife probably 5 hours to just remove the half of the hood that was done. 2 cans of 3m adhesive remover and a lot of swearing.I put 3M file over every inch of the truck Except the rear tail/lift gate and the roof behind the sunroof where the roof rack is.
I also did the headlights and fronts of the rear view mirrors.
It's been on 3+ years and shows no sign of peeling.
the headlights are as clear as when I took delivery.
That is one of the major realistic differences between the quality stuff and cheapo.Removing the wife’s ppf after 4 or so years was a damn bear. Just came off in thousands of pieces. Too me and the wife probably 5 hours to just remove the half of the hood that was done. 2 cans of 3m adhesive remover and a lot of swearing.
What key did you get? Any notes on programming?Amazon keys and Techstream. In about 10 minutes I had 3
I just ordered the 3m from Amazon. Hopefully it's real and works well. I'd be fine with needing to replace it every 3-4 years as long as it's easy to remove.
That should not be needed if the carriers and latch is adjusted properly. SeeAdded a spacer plug to my Slee rear bumper to stop the tire carrier from rattling while driving. The model is Carrier Lock Plug.
I used Ebay. Techstream was straight forward. Just had the keys separated by about 20 ft when programming. Go over the instructions before doing one and it can go smoothly. I also used 1010keys to send pictures of my physical key and they were able to cut the keys to fit (another $30).What key did you get? Any notes on programming?
Only another 700,000 miles. Keep driving.View attachment 3897261
It’ll be a while before I see something like this again.
Mylar balloons should be outlawed.Have had a nagging melting/burning smell coming from the truck for days. Worried about the likely expensive cause and fix. Finally located it - mylar balloon baking on the cat. Whew…
Of all the mods we’ve done this is has been one of the best if you poll all the occupants.Hamilton Auto CarPlay installed. Less than an hour all in. Ran into one question and I called them and they got me the answer in 5 mins. Very easy install and glad to have CarPlay now!
Did you do the install yourself?Hamilton Auto CarPlay installed. Less than an hour all in. Ran into one question and I called them and they got me the answer in 5 mins. Very easy install and glad to have CarPlay now!
