What have you done to your 200 Series this week? (68 Viewers)
Getting closer!
No I don't have any photos of the mount before installing. They obviously moved the mounting holes toward the firewall so the compressor front filter caps wouldn't interfere with the fuse box hinges.
They must also have extended the base aft to mount the manifold further back, as the wires of the compressor limited it’s aft most position regardless of the positions of the holes.
The covers are well worth the price and Equipt is maintaining an inventory so shipping times have not been bad at all.
this x50. I ordered mine direct. Received them yesterday, they are great products. I kick myself for not putting them on my 100 series.
They are especially valuable in places where it's hot. Gettinng into hot leather seats in a Texas summer is a beat down. The fabric and design are well worth the price. Either way of ordering will work.
Did a little winter prep by installing a set of Escape Gear seat covers from Equit, then gave it a good wash, used a synthetic clay bar and applied a ceramic coating.
Love these seat covers. I looked on Equit's site, and noticed they mention "with monitor, without monitor"? My truck is a 21' heritage, so what do I need? Do you recommend purchasing directly from Equit?
Pretty sure the monitors in question are the ones on the backs of the front row seats. If you have rear entertainment system you want w/ monitor and if you don't you get w/o monitor.
Heritage would be without, unless you had dealer install monitors on seat backs.
Took off my noisy TC upper arms and put OME on and it’s so much quieter. Also put on new 555 inner and outer tie rod on. This truck drives so smooth now. Turning is super easy. And no more squeaking. So nice.
Nice. Did you tab the brackets to attach to OEM rack? Can we get a look?
Today was just testing etc. It is very basic bracket L shape + small plate with two holes and two bolts. To go around the OEM roof rails. For my taste it goes to far from roof rail. I will make photo of bracket later and post. Awning is not on car at the moment. Tomorrow I will get custom bracket. I hope to have better fittment. It will be more shape specific to roof raill.
You see, one side is too long. For my taste of position of awning it should be cut off. Second thing that I don't like is the gap betwen bolt and rail. Awning doesn't move regardless the gap. I didn't tighten bolts because I put it just for photo to show you. Everything of above can be easily improved but I will wait new bracket to came in and check it first. It will be very simple bracket but hope to be more tight to rail and round on one side, just like oem rail
Fixed a rocker panel hit. Was able to save fender panel. Not perfect but pretty close.
A little light added to to dark side.
Do you have a parts/link list available?
2 Whelen 3SRCCDCR leds, about $56 ea from Sirennet
1 Uxcell DPDT latching Waterproof rocker switch, Amazon $10
1 pack (3) DajierTek door pin switches, Amazon $7
2 leads of 18g wire about 8 ft each
1 lead 18g Red about 12ft
1 lead 18g Black about 2 ft
1 lot TechFlex Flexo Clean Cut Loom 1/4” and 1/8”
1 Bussman Mini low profile add-a-circuit w/ 2 amp fuse.
Decided to run a couple of trails near home yesterday. Did the Yellow Pine Mining District trail and the Table Mountain trail just outside of Goodsprings, NV. Both rated a 5 (out of 10). The view down the ramp is an old hang glider launch. Not sure if it is still in use. Looked a little weather worn.
Got lost on the second one as it was getting dark and ended up on a very sketchy shelf trail dropping into a steep canyon. Finally found a place to turn around.
Was a beautiful day out in the mid 60's.
Headed to the 108 year old haunted Pioneer Saloon afterward for a Ghost Burger and some live music. Has a really interesting history.
