What have you done to your 100 Series this week? (23 Viewers)
Question, does anyone know what the little plastic plugs that the OEM screw goes into on the fender lip?
Just realized the other side is missing them
might be looking for these
ran rokblokz on the wife's subaru for few years. they held up quite well w/ a fair amount of gravel road travel.
I have a spare tire winch thingy somewhere in the garage but no key. Happy to give a way to some in need. Not sure the key is more than $49 at the stealership :p
It is easy to remove the key from the spare tire carrier… see this thread…
In need of assistance. I purchased the SAE Rigid fog lights to go with my front bumper. The lights come with Deutsch connectors almost same as the fog lights on the car. I was hoping it would be plug and play without the need for the harness it came with. The two connectors don’t seem to mate very well. Can anyone tell me if I would be able to cut the male end off the rigid harness and splice it into factory harness so I can control the fog lights from the factory knob on the steering column. The factory wires look to be a thinner gauge than the Rigid harness. Thanks.
Pretty simple, I ended up cutting off the factory plug and wiring in a Deutsch connector to mate to the aftermarket lights, in my case Diode Dynamics. Works with the stalk factory fog light switch took all of 15 minutes. I ordered the crimper and Deutsch kit off amazon I can link in what I used if you are curious
Yes please, no issues with the difference in wire gauge? The stock harness can handle the load?
Swapped a leaky power steering pump out and grabbed a serpentine belt as well. I plan to rebuild the OEM steering pump and keep for a back up. Ran out of day light last night to bleed the system. Quick work this morning.
Got the wolfbox G900 Pro mocked up and working. Installed the Jerry can holder on the TCC bumper with a little help.
To do:
-wrap up install of the wolfbox and hard wire
-wire up the license plate light with some Deutsche connectors (loom is already run out to the swing arm)
-throw my Aussie plate I got when living in NSW in the OG spot on the tailgate
To do:
View attachment 3971837View attachment 3971838
The truck is super nice, but what are the specs on that shred sled hanging on the wall? Been a minute since I’ve seen a nose guard on a skateboard!
I’ve built and ridden longboards/slalom boards for 25 years and while pricey this one is awesome! The trucks come setup exactly how I’d tinker with them to get the perfect feel (higher quality urethane bushings that are mixed and matched, wedges)
added the nose guards because we’ve got some groms in the house 😂
The other short board in the photos is a Landyatchz dinghy fender. They’re great too but a traditional skateboard deck construction and stiff. No stringers or fiberglass like the Comet.
To do:
Is this 12 inch screen? Is it fit without interfearing with visors?
I'm about to try the 3 camera version with front bumper camera - not sure about the 12 inch fits in between visors.
The other short board in the photos is a Landyatchz dinghy fender. They’re great too but a traditional skateboard deck construction and stiff. No stringers or fiberglass like the Comet.View attachment 3971849View attachment 3971850View attachment 3971851
That’s rad! I’ve still got my dad’s 78 Duraflex Splinter. It’s fun to carve on, but I mostly ride 8.25” popsicles still. I’ve got my daughter (17 months) starting to roll around on her butt, she loves it!
Anyway back to your regularly scheduled Land Cruiser talk… Rolled over 307k this week too!
It is the 12” model and I read that it interfered with the visors but I don’t seem to have that issue. I have a 98 so my guess is that’s part of it. It’s very close.
I have duplicate set brand new in box I’d sell for $300. Been meaning to list it.
-wolfbox g900 pro extended package (not-Tri)
-wolfbox OEM bracket 190
All you’d need to order is get the bracket adapter from eBay.
So I did the same thing a number of years ago. At the time I figured everything was close enough I would run it without too much worry. You comment made me worry again so I checked...
Stock bulb I believe is the H3 which is 55 watts. As long as the light you are putting in is around the same, you should be fine. I went with the Dynamic Diode 6" bar and that one comes in at 27 watts. Looks like one Rigid option is 40 watts.
