What have you done to your 100 Series this week? (117 Viewers)
What parts are these? could you list them out? I've been replacing everything I can think of in pursuit of the clunk (CVs, hub flanges, diff bushings, as well as UCAs). The last thing I can think of (outside of backlash in the diffs somewhere) is motor mounts.
Cushion: 41651-60010
Support Assy: 52380-60040
Stopper: 41653-60010
Support Assy: 52380-60030
Stopper: 41653-60020
transmission mount: 12371-50081
engine mounts (2x): 12361-50121
Both mine and my buddy's got 24G LRA AUX tanks installed 👆. Looking forward to cut ⛽ stops in half! 🛣️
ARB crew 👍🏾 I had the same front deluxe bar + side rails with my D4D Hilux and ironically came in clutch from fender-benders several times driving in the city.
Went with ARB because that's well tested and regulated in Ausi. ARB or TJM were my options from AUSI back in the day. There are more better looking stuff out there now though.
Six years owning my 100. Am I the only one that just found out there are cup holders in the back seat? Was just chilling in the backseat wondering what was behind the “caps” thinking how outrageous it is there are no cup holders and this thing pops out after prying it open with a flat head 💀💀💀💀
I just figured out there's two MORE cupholders in the front, if you lift the upper section of the center console, on the underside of it is a plastic release that folds down a tray with 2 extra cupholders!!
I know about that one but sadly mine didn’t have that option 😩
New to the 100 series world. Just found this gem. Less than 48,000 miles from new in 2001. Paid a deposit and will collect soon. Must be one of the cleanest 100 series out there. Still has the original plastic covering the carpets and door panels from factory.
How much do you think I paid??
Got the wheels and tires on.
17x9 +58 Lodio Drive Cinq from Japan
285/70/17 Kenda Klever AT2
25mm spacers
I’m sure this is obvious to most on this forum, but I didn’t know that the front hub bolts foul the hub centric lip on most spacers. I didn’t want to go to a 1.5” spacer because that would have been too much poke. Ended up having a buddy machine some relief cuts, and it worked great.
I did break a front wheel stud removing the stock wheels. Getting the hub/rotor off and separated and pounding out the old stud on a 368k mile truck from Wisconsin was a bitch!
Anyway, here she is.
After all the tinkering and
25mm spacers
Wheel + tire + spacer fitment looks good. And those set of wheels complement the LX really well. Hope you torqued the lug nuts of the spacer to the hub to spec (100 ft-lbs) and maybe consider using blue loctite just (applied on both the thread of the nuts and the bolt for full coverage) for added insurance that it won’t back out. Because there is really no way to check the condition of the spacer lug nuts if they are still tight or may have came loose w/o removing the wheel after long road trips. Just added layer of safety precaution.
SpiderTrax come with Red Loctite
Thanks, I made sure everything was torqued especially the unseen nuts. I’ve been running spacers off and on for probably a decade so I’m used to the extra care they require.
