What have you done to your 100 Series this week? (10 Viewers)
Installed LED reverse lights in bumper reflector holes. I’ve done this several times before in other Hundys but these are a bit different.
These are only about 3/4” in depth so there’s no need to cut out the reflector hole to fit in flush mount light like before. Only thing needed is to trim the back edges of these lights. Fits right in and allows you to put reflectors back on should you want to in the future. However, these are not the most expensive lights so may not last two long.
A few weeks ago a gust of wind destroyed my NAPA awning, I didn’t have a chance to secure it using the anchors before a rogue wind came in. Anyways, I picked up an Ironman 4X4 awning and am very impressed so far, aside from the gaudy neon green accents it looks top notch and am glad to confirm that the ARB awning room bolts on without any modification needed.
Link from where your got it?
Finally got around to mounting my GMRS and a USB charging port (w/ voltage readout):
Ironman 4X4 is down the road from me. I believe they only have one location in the US.
However, you'll pay the same price as I did if you need it shipped. Ironman usually offers free shipping.
The ARB awning room (incase that's what you're asking) I also picked up from a local off road shop.
Ah ok makes sense!
Thanks!
Tracking down water leaks. PO had run black RTV all around the 3rd brake light.
Took forrrrever to clean up. Used butyl tape to reseal.
Next up, roof rack
I repaired the same issue a few weeks ago, and can confirm that it did in fact suck. My light was cracked in half and glued together as well. After ordering a DOA eBay special, I bit the bullet and replaced it with an OEM. For removing the RTV, I found that a fiber wheel (aka Scotch Brite) of the non aggressive variety really helped it didn't seem to burn through the clear coat, and I wasn't worried about looks since it's under the light.
I thought about that at the time but was afraid I'd mess up the clearcoat.
Luckily my Wurth eraser wheel made it pretty easy and it didn't phase it
