While replacing a bunch of coolant hoses I found my heater control valve was rotten, so I tossed it in the trash and ordered a new OEM valve. That order was cancelled and I had to get the truck back together, so I ran to the local parts store, grabbed a Chinese valve, and re-ordered the OEM valve. After installing the Chinese valve I realized it didn't come with the arm (which is still attached to the valve I removed, sitting in the dump). I left the valve to open so I could perform the coolant flush and check for leaks, expecting only heat from the HVAC system. To my surprise, both the heat and AC work the same as they did before I replaced the valve (both work well).
Now I'm confused, what exactly does that valve do, how, and when?
