What do I have? 40 newb (16 Viewers)
So on to a new subject.
Torque steer: with throttle input or aggressive deceleration my 40 has a tendency to point itself where it wants, 100% feels like it’s coming from the rear. It has done this since day 1 of getting it going. It was always manageable. I have all new spring bushings.
It’s borderline dangerous with 300+ horse pressures.
So let’s see what we can dive off into the rabbit hole and find out.
Step one. Retighten all u bolts. Again.
Step two. Hope step one helps
Step three. Drink beer and think about it.
Open to suggestions.
Virtual beer time!
Sooo - how are your springs? Have a cruiser lean?
How is your pinion angle - could worn ujoints etc cause rotation of driveshaft/axle with heavy torque load and then translate to your springs.
And drink.
Virtual beer time!
And drink.
Springs are pretty “new” few thousand mile HEll For Stout 4” springs. Doesn’t every cruiser lean?
All new driveshaft in the rear since day one. Freshly checked and lengthened with the swap.
Pinion angle looks pretty, I think it’s 4* which is what I set my t case at when I did the swap. Which is nice because I have no driveline vibes now.
I ran a lockrite for about 10yrs and the torque steer was atrocious. On acceleration the right rear would squat and pull badly, on deacceleration it was exactly opposite. I would anticipate this because I was in control of the throttle. I eventually installed a Detriot locker and for some reason it's hardly noticeable, and quite. I wheel with a lot jeeps, that ran lunchbox's and they had the same characteristics.
You’re right. Lunchbox. Aussie brand.
It’s a love hate. I love that it works when it needs to. I love that it was dirt cheap on trade.
I hate it locking and unlocking when it does. It’s definitely annoying at times.
My next rear axle will have something different. Maybe a Detroit style. More than likely a selectable locker of some sort.
Mount a go pro underneath and see what’s twisting? Frame, mounts….?
Also wanna be first in (on this page) to say “links”, haha.
I'm with ya, they're cheap and effective. I've been running a Detroit for probably 20yrs. It rarely makes a noise and has ran flawlessly. I have an arb in the frt. I put it together a long time ago and it sees more work and trail anymore. My other 40 will get a pair of arb's or maybe a Detroit in the rear.
It is 1000% your lunchbox locker. It will take you 30 minutes to remove it and your problem will go away
Last night I was able to stretch its legs a little.
It will run 70 with zero effort. Really wish it had another gear at that point but it doesn’t “ need” it.
It is very quiet and harmonically happy at 65.
Hoping to put some real miles on it this weekend.
I don’t love the driver seat position, however I’m going to slide it back a little and adjust that soon.
You’re right, this is an easy solution. I have 2 other 4.11 thirds I could just swap in quickly.
You don’t even need to swap the whole 3rd, you can swap the spider gears by just pulling the rear cover and shafts
Correct. If I can find my old parts.
I’ll probably just deal with it until I swap axles.
It really isn’t terrible unless you are doing race car things.
Edit - In all reality I don’t need a rear locker currently. Maybe I should just pull it out sometime.
Family is out of town for the next week. I have a pretty big lunch list I hope to knock out.
I got home tonight after the airport and started in.
Fresh redline heavy shock proof in the trans and transfer case. (Really hope the koolaid helps with noise)
Modified shifter for t case / 2 low also
Modified trans cover, added another layer of sound deadening material under it.
Started on my actual seat mounting and this is taking much longer than expected. I really wanted to have this done tonight so I could take a road trip tomorrow to a swimming hole. However I thought I’d be a nice neighbor and not run the grinder after 9pm. Also I’d like to sleep on my design and think through it some more.
Up early to knock out the seat and hit the road I hope. It’s definitely strange having no one else in the house other than the dogs.
Always a reasonable plan to re-examine a plan in the morning. Had this similar light bulb moment with my own seat..eventually added a 2” spacer to the rear mounting legs to tilt it forward more … worked great…good luck.
Alright, it’s morning.
Let’s see that seat mounting.
I put the Kool-Aid in my 62 to address some notchy shifting. For what I paid for it, I will keep telling myself it did something positive.
That’s my hopes as well.. $20 a quart it better at last have some placebo effect.
Mine shifted great. Had a bunch of gear whine which I attribute to the fact it’s always been there, it’s just further forward and more noticeable now.
Working on seats currently. Started the grinder at 7:30 this am. ☕👨‍🏭
Done enough for today.
Needs paint and some finish welding. But it’s safe and ready for a trip.
I’m amazed how much room is in the stuffy console. Pretty sure I just increased the interior storage 100%
Even gave it a quick cleaning.
