What did you do with your 60 this weekend? (11 Viewers)
I also tore down an axle this weekend. I bought a complete front end to go back to spring under and hadn't swapped out the diff yet. As it's becoming winter and snow days are looming, I figure it would be best to have matching gears front and rear so I can use 4wd. If anyone wants a SOA front axle,, hit me up. I'm going to put all of the parts in the parts cooker at work to clean them up too.
You can get Vessel Tools from their US distributor.
Vessel Tools USA
A JIS screwdriver or three is 100% necessary for working on any Land Cruiser.
Another convert to JIS screwdriver set, here. I picked up a Vessel set recently and the large driver was the only way to get the door armrest screws to drive home into new white plastic mount bushings. Took lots steady pressure but worked out perfect,
Have a bit set on order now too, thanks for the rec,
Still fighting some odd intermittent lean spike issues with my sniper, and more recently a hanging idle intermittently. Found my Lokar accelerator pedal cable frayed and bunched up. Kind of odd for under 3,000mi.
Honestly this Sniper kit has been kind of a pain in the butt. I wish I just would’ve desmogged and rebuilt the carb instead.
I installed the AFI system and 90% of the time no issues, but I also get a lean condition under certain load conditions. I am wondering if the long stroke causes an issue with the fuel map. The issue I had with the factory carb was how bad it ran when cold. Always had to fiddle with choke until it was warm.
mine runs great under load, no issues there at all. It will intermittently lean out, stumble badly, then recover ONLY when returning to idle. It also doesnt want to cold start to save its life, and again, even that is intermittent. Yesterday it cold started beautifully. High idle, running rich like it should when cold, and ramping down to normal idle and leaning itself out to the target AFR as it gets some heat in it. This morning, with no changes, it cold started, s*** on itself, idled at about 300rpm and then stalled. It restarted and s*** its pants again, then stalled and died. Restarted fine.
when I say intermittent, I mean like I drove it 2 weeks ago for 50 miles without an issue.
Assuming everything else is in great condition (ignition, vac leaks, compression, etc) have you done any tuning for hot starts? My 40 has a sniper and I tuned the best hot starts I could, then added fuel, etc to the cold starts to get them where I want. Reason being, you only really get 1 cold start per day to tune, but infinite hot starts, so tune great hot starts, then finesse the cold starts.
Another oddity I’ve found in the cold…. You turn the key and the sniper runs though it’s boot up for about 5 seconds. In this time the manual says don’t crank, just turn the key and let it go through it. So; turn the key and put the pedal to the floor immediately and hold it there. The sniper will give a prime charge of fuel in this time period (should hear it click). Well, with the butterfly closed on the throttle body this fuel charge sits on top of the throttle plate. But if the pedal is to the floor it shoots the fuel to the intake. This has been working for me the last couple weeks in 30+/- temps for quick startup. May not work for anyone else. (That’s the disclaimer).
It's desmogged so very minimal stuff to leak vacuum. I've meticulously smoke tested the intake for leaks though and have made several repairs. It warm/hot starts perfectly. Same with the exhaust side pre- 02 sensor, made sure there are no leaks via soapy water and a shop vac pushing thru the tailpipe. I took it all apart the other day and removed the heat riser and rod from the manifold due to a leak at the bushing that won't hold with JB weld. So I'm taking it to get welded this moring to eliminate it once and for all, I can weld but I don't want to attempt a repair on cast iron. I adjusted the valves last winter. Any adjustments or repairs I make from this point forward will have to wait until spring to be tested. It's in the garage for the winter because they've already salted the roads in wisconsin.
The part that I don't like is that its intermittent. If I had a vacuum leak, poorly adjusted valves, or low compression I feel like it would struggle all the time, not just intermittently. It runs really, really well 95% of the time. I think the lean spike returning to idle and cold start issues are separate though.
My 60 with Sniper does the same thing, causing my idle to momentarily drop below 500rpm and it sounds like it is a fairly common issue (not just on Toyota I-6's). I've found that the lean spike seems to be worse when it is cold outside and the engine is cold. It's in the 30's overnight in NC this week and I've been playing with Idle rampdown and IAC settings to see if anything helps (they don't appear to). Today I actually raised the idle from 700 to 750 rpm and that seems to have improved it. I'm not sure if it is because the lean spike doesn't drop the RPM quite as low (i.e. 50rpm higher) or if it's because the IAC is running in the 7-8% range at idle whereas I typically have it adjusted to ~3%. I intend to adjust the idle screw this weekend to bring the idle IAC back down to 3% at 750 rpm and will see if that improves things.
Yeah I’ve messed with those settings as well and also fuel enrichment on cold starts with no real results. I have my idle set at 750rpm and my IAC at 6%.
Im using the @TRAIL TAILOR front and rear coil swap kits.
I'm looking forward to following this since I have a front axle I'll be doing the same with.
On another topic, I crossed into the US of A today to pick up the headliner which I hope to do something innovative with.
Got 4 solar panels, duel battery system and charge controller for Aux battery setup.
this is odd....Cold Starts at 9600' was perhaps the best part of the Sniper with my rig....never failed!! That and never stalling coming to a stop etc.
2001 nissan pathfinder
had a free day, needed some seats, went to the junkyard, and these looked the part
100% no way close to 'bolt in'
fabbed all 8 mounting corners by trial and error.
I like how they are modern enough and jive with the rest of the blue/grey interior
Finished my first ever carb rebuild tonight. Well, it still needs adjustments but it’s completely reassembled. Only ended up with one mystery part left over! I would call this more of a restoration - I had to steal parts from another spare carb to replace missing and damaged stuff, fully disassembled everything except pulling the throttle blades and shafts, cleaned it and shined up all the aluminum and yellow zinc pieces. Every screw, washer, linkage, etc. I hit most mating surfaces with a light pass of 1500 grit just to identify if There were any imperfections, as well as the power piston (so it wouldn’t be sticky) and the accelerator pump hole.
I did this with both the Keyster and Hygrade kits combined, new secondary vacuum diaphragm, leather accel pump, stainless screw kit and new Aisin float from City Racer, etc. I kind of went nuts. I think combining the two kits was beneficial: the Keyster had a higher quality feeling gasket and a fuel filter on the needle valve, but the Hygrade had venturi gaskets and some other things I wanted to replace.
No idea if it will run once installed. Fingers crossed.
This was the only leftover part:
I’ll swap this onto the truck tomorrow and see what I get. Then I can get back to my t-case rebuild project.
