What did you do on your 70 series today?
Hi
I did the front knuckles after 1.5 years; new seals and also bearings once I was in there. Just the normal stuff once the soup seeps out. Guess the seal went out due to clogged breathers. Haven't been into the rear axle or diffs since I own the truck. Brake job all around, but rather to be on the safe side. New radiator hoses and -after 4 years- new handbrake cable. TLC, that's it. Also painted the frame and conserved the body with cavity grease.
The PO who had it sitting in the barn was an LC enthusiast, who was in his late 70s already. (I was told only later). When I assessed the truck later, I came to the conclusion that the PO certainly restored it to sell it, but did a good and honest job to provide a reasonably restored and maintained vehicle, for what the base was. Not perfect, but in good working order. But, apparently, at some point, he ran out of passion, time or capabilities, as there are some aspects on it (e.g. the paintjob, the side steps and the fender flares), which do not match the standard of the rest of the vehicle.
I certainly knew it was a gamble to buy this rig. And yes, experts may call it overpriced (I won't tell $$ 😉) But I don't have the facilities to restore a truck myself. I got a sound foundation that enabled me to do the rest by myself and learn on it. I got what I was looking for and I'm happy with it. I know, I was lucky, though.
Cheers Ralf
Hello,
Great story.
Sometimes you have to pay a little more for your truck but you get a better foundation to work with.
The front axle soup you describe is normal after 20+ years. It is possible the PO replaced the rear axle seals and bearings, which, again, are likely to give up the ghost after 20+ years.
One good thing about Land Cruisers, 70 Series in particular, is that you can work on one system/subsystem at a time.
Juan
OEM spare wheel tire cover
Part number: 64771-60170
My speedo and tach have been malfunctioning for a few years (and my needle was broken off when I got the truck). In the cold the tach doesn't work for about 10 minutes. The speedo works sometimes then it doesn't. But a 24v 70 series cluster isn't usually available at my local Canadian Tire...
Enter my man Zubair, who sourced me a beauty cluster from overseas. It only had 63k kms on it! There were a few broken mounts on it (so he also sourced me an intact housing) so I'm in the process of swapping things around to build a nice instrument panel.
So happy to finally fix this. The wonky, bent and glued speedo needle drove me crazy everytime I looked at it. And in winter I knew I'd be guessing speed and rpm much of the time. Not any more.
The only down side is that my odo is now rolled back from 303k kms to 63k. I'll keep the old one (and a pic side by side) for proof of mileage in case someday she moves on...
Maybe she'll think she's a new truck?
Well done! I replaced the bulb and housing for my high beams when I repaired mine a couple days ago, but it did not fix the light to come on when I shine my bights. sucks because I don't know what to do now besides replace the back electrical panel strip. Everything else works just fine.....
Hello,
I noticed your truck has a grommet for the indicator lever. I also noticed you have the pull-up hazard switch. Both are standard in the soft top 70 Series, not in hard top models.
Did it come with the grommets?
Just curious.
Juan
All the ones that came with the removable top doors had the weatherstripping on the stalks like the soft top versions . These also had the hoods with the blocks to lay the windshield frames on and where reinforced
I started my BJ70 yesterday and let it warm up to operating temperature. The 13BT started like a champ, only a couple of revelations of the engine and it was going, about 10 seconds of preheat. 👍
303,698KMS will do that to a needle
…maybe they saw some hybrids or full electric models being imported for the underground mines out west…
HZJ79s are now legal to import into the US.
You might want to specify that the single cab 79 is legal for import now, the crew cab is still several years away. It seems that a lot of folks have a hard time following the 7x timeline and all the different models and the sometimes a bit confusing numeral designation.
I personally don't get the hype about needing the front coil suspension update while most of those people look down on the "light duty" models with coils all around . On any 75,76,77,78 and 79 it is the rear suspension attacking your spine and kidneys , the front coils on the HD models are not that big of a improvement on the leaf springs as the weight of the heavy engines on top of them make em work fine unlike the HD rear spring packs on unloaded cruisers with a 1 ton load capacity . Plus the 75 removable cab pu looks so much cooler then the fixed roof version....... at 6.2 I am cramped in both anyways ;)
@joekatana ….. “attacking your spine and kidneys”
Now that’s funny. 😁
Many years ago overseas I tried to cram into a armored Hilux wearing full kit. On the outside the truck looked stock. When you got inside you could see the bulletproof glass. You could feel the weight of armor panels in the doors etc. ......Imported to the US, modified to spec, delivered to US gov agency and shipped back out.
Aftermarkets?
Canbus fixed my high beam indicator light issue.
JTX Toyota CANBUS Module (Pair) – JTX Lighting - https://www.jtxlighting.com/product/canbus/
I have a set of the 12V version if needed. Ordered 24V and they sent 12V the first round.
Swapped the Autometer trans gauge that I never wired for an Auber over the weekend. Curtains match the drapes now. Pain to crack that 22mm output line! Penetrating oil/time, heat then the crows foot and a breaker bar finally did it.
Intended to use that Autometer gauge and short sweep sensor with a Radd Cruisers drilled/tapped union. The Auber sensor is too long and would restrict flow. So, pivoted and used an OEM union (9407-20006) with an adapter. Eliminated the stock sensor/warning/dummy light.
If anyone wants to run this union with the Autometer gauge LMK. I'll sell the get up. It's all shiny new.
When your water temp matches your trans temp. Confusing. I'm slow and forgetful and fairly ugly so I may need to label these. I'm all Auber'd now. Boost, EGT, trans and water temps.
Test drive to work today. Stopped to check ATF level and got a full body shot with the new Alamosa antenna. No trans leaks at the union. Get the skids and front driveline back on tonight. Good times.
The humidity levels dropped, it was cool and clear with an easterly blowing and the sun came out, and the Mrs didn’t hang the washing out………sand blasting time.
Quite painstaking and only managed half of it , the sun still low in the northern hemisphere but I needed to be thorough, and get some primer on before the sun lost its warmth.
The other half awaits another day.
