Project Fluffy is Running!!!
VID_20171105_102521.mp4
Couldn't think of a better way to share the start up video from today, that is the link to the vid in my google drive.
What it got:
-Timing Belt
-Water pump (with correct gasket and not clear silicone...)
-Spark plugs (Denso not autolite -_-)
-Spark plug wires (again Denso, and not melted autolite...)
-Valve Cover Gaskets
-Radiator (Denso, the original brass tank one finally corroded through...)
-Serpentine Belt
-Oil pan reseal
-Oil Pan fluid level delete
-Transmission pan reseal (with just the felt gasket, not felt and silicone...)
-Exhaust hung correctly (not with coat hangers attached to rear lower control arms...)
-17" after market wheels with slightly larger tires (left over from the Camry)
Took it down the road and around the block a few times, no more overheating or massive oil leaks, this whole process was fixing up a hack mechanics work...
Now its onto the electrical and figure out why the brake lights and shift light will not work, and the brake light switch was replaced...
I also have to figure out the power tilt steering, I can;t even figure out if it has the normal grinding culprit due to the motor not working at all....
I have a feeling I am about to get into a wiring mess, this thing was really hacked into, but after the test drive, its staying with me and my partner in crime.
The plan has changed and my partner in crime on the project and myself have come to the agreement, we are going to autocross it.
So after we get it so we can actually drive it down the road (also needs some lower ball joints and maybe upper arms...) we will start with some slight modifications (LS400 brake upgrade, some coilovers, some stiffer sway bars, and some seats that don't have us on the gangsta lean all the time...)
Like I needed another project in my life, but this thing is so cool!!
What it got:
-Timing Belt
-Serpentine Belt
-Oil pan reseal
The sad part is, this is the second time I've done that...the hard ware stores seem to only cary 7/16-14 Grade 8's in 4" (too short, what I currently have) and 6" (too long, would need to cut the entire threaded portion) so I'll need to head back to Fastenal this week to grab a 4.5" bolts.
