Weld tie rod end nut?
Cary, NC
So I'm replacing my tie rod ball joints, and I guess I put a little too much on the nut, and it is stripped. Won't back off either. The kit had a lock washer in it, which was not used in the oem application. I should have known to leave it off, but now there are not enough threads showing to insert the carter pin (because of the washer tickness). I'm thinking I'll just tack weld that nut on and be done with it.
Opinions???
Remove the junk piece and install a new one properly.....it is your steering, and not just your life in the mix bud....
So where did you get a tie rod end kit that had a lock washer with it? :rolleyes:
I've had it for 2 years, so I don't even recall. Funny thing is, only one had a lock washer. It's the one that connect the relay and tie rod at the pass wheel. I think it came from JTO, but not sure.
I wonder if I can buy just that one piece? I'll check some vendors, but I'm sure it won't be cheap since it's not going to require a full kit. Hell, maybe NAPA will have it.
get mine from napa most of the time put some pressure on the end use jack or whatever nut may come off then good luck
