"VSC OFF" Light not working when in 4L (1 Viewer)
Texas
Recently I have had all of the lights associated with 4L go out on my LX470. Before, when I shifted from 4H-N-4L both the center diff lock switch as well as the VSC OFF switch would come on on the dash. I replaced the center diff lock switch on the center diff and now that light works but I still don't have the VSC OFF light coming on.
Is there a separate switch that actuates that light that I can troubleshoot?
I also have my "D" selector drive indicator light out on the dash but haven't replaced it because it's bright at night, could this have something to do with the other lights on my dash going out?
Thanks for the help!
D light is almost always burnt-out, on the 100 series. Is VSC OFF light on pre engine start systems check with key in on position, it should be.
It is not, but neither are the ABS lights or center diff lock switch. Below is a picture for reference with the key in the off position.
Is it likely all of these lights have burned out recently? Could this be a blown fuse?
I'm afraid I wasn't clear pre-check last for about 1 second, then switch to picture you've posted.
Just as key turned to on, first second system check.
After first second system check, lights that say on:
I don't have air bag light that you do, maybe become I've 01 LX & LC.
