Is it possible to un-seize a seized viscous coupling. ...
if it is ... how is it done??
Pretty simple job, pull the rear case off the transfer, the VC will be inside, remove the retaining snap-ring (pretty deep in a hole, kinda pain) dump the VC out. Clean the case surfaces, light coat of Ultra Gray RTV, torque it back together.
I say remove it, if for some reason you don't like the way it drives, can always get a replacement and install. I have a few good used ones, but likely not worth the swim across the pond?
