Check out SOR's site...fat end of the shims go forward. Like NocalFJ60 said, backwards makes it worse.
That also makes me wonder, should the rear shims be pointed toward shackles, or is that different?
I don't know about the tcase in a 62, but a one-piece or split case won't lube the output shaft bearings properly when being towed in neutral and it will grenade in a very short time. Search around the '40 board for instances. You have to remove your drive shaft (or drive plates on a ff) and make sure the front end is unlocked.
why remove rear shaft ?????? tranfer case in n should do it ....unlimited speed tow
