The front 3rd member with 4.88 gears weighs 66lbs. I will find out how much the rear 3rd member weighs tomorrow.
Pulled a couple main bearing caps yesterday on the '67 F135 in hopes of finding the source for the trash that had collected in the bottom of the oil pan.
These look like the have another mile or two left on them, lol!
Appears as if my clean, paint and re-gasket approach has taken a turn toward full rebuild.![]()
P
Project not so nice v.2.0
Still not painting the body...dammit!
Yeah, the 205 setup is just a little bit larger.Got moonshine back in the healing room, and pulled the D300. This will be the last time pulling a transfercase without a jackYeah, the 205 setup is just a little bit larger.
Pulled the ecobox apart to put in the new input gear.
New one on the left foreground, old one on the right. The bearing journal is much wider on the old one. The NP241s (guts of the ecobox) came with 16mm and 24mm wide input bearings. I was told this one had the 16mm, and ordered the input shaft accordingly. In fact, it has a 24mm input bearing. Hoping that powerdrivendiesel will allow me to exchange the shaft I got for the one I need.
Not a big deal. Will get it sorted, then put back together. This is what the new input shaft will look like inside the planetary gearset.
Pulling some pork. These 4 Wheel Drive turbo diesel engine hoist really make a difference
