I'm having an odd problem; I've been troubleshooting it for a month now with no end in sight. Disk front, late model drums in the rear.
My front brakes don't work unless I double pump the pedal. Rears work great but if you've ever driven without front brakes you'll know the truck stops for s*** on just the rears (which also lock up easily). After a double pump they work properly for a short time (30 seconds? I dunno).
I've readjusted the rears, bleed the brakes, eventually replaced the master. Now the symptom is still there, but at least its consistent; the fronts ALWAYS need 2 pumps.
Today I thought that it HAD to be air in the front circuit, no matter how many times I bled it. So I got a Power Bleeder and REALLY bled the fronts; not a single bubble. And, of course, same symptoms.
Is it possible the calipers are bad?
