Turn Signals/rear window stopped
FJBen
Northern Colorado
Driving yesterday, put on turn signal (occasionally i use them) blinked once the nothing...hmmm? checked all fused looked fine. Moved them around alittle...still fine...
weather was getting bad so I went to roll up the rear window...no dice...
Hazards work fine, everything else works fine. The rear window works fine if you use the key to open/close it...any ideas???
Turn signal blinking once usually means:
1) Bad ground ('specially in front)
or
B) Burned filament in the bulb
But I've had it happen when my battery was weak too...
or
Well actually it doesn't work at all now, it only blinked once and then stopped the first time. Now no blinkers and the rear window switch doens't work either... :confused:
2nd the GROUND. Claudia
treerootCO said:
You could try backing it into the garage door again. :D
I'll see if my wife is down for that again! ;p
and now...just went to lunch...no oil pressure gauge, temp, or fuel gauge and heater stopped...WTF???
looked...now there is 1 blown fuse.... :confused: WTF? lol nothing has changed in the past two days...maybe that is whats wrong... :doh:
Well I shoulda known what is was... :rolleyes: just grabbed the fused jiggled them around, pushed them back and fourth...low and behold...all is well in Cruiserland again...
thanks to all for help
I'm having the exact same prob with mine. I even took mine off and attacked it and the base with a wire brush. Worked good for a day, then it happens again.
I think I'm gonna have to disassemble and clean all my connections on the fuse block. That should clear up the problem...
My 55 is still garaged and happend to notice mine also clicks once and stops, whereas hazards still work fine. i'll try the fuses i guess.
