turn signal Flasher / Hazard Flasher (1 Viewer)
maa
My fj40 has a build date of Oct 71. Can someone advise if there is a separate flasher relay for the turn signals and the hazards, or do they operate off of the same relay.
thank you
BeerM3
Wamego, KS
If the original wiring is still intact and nobody's monkeyed with it, yes the '71 has separate flashers for both circuits. They're both very picky about having good grounds where they're bolted to the firewall, and at each light. Turn signal flasher will be under near your clutch and I believe the hazard one is tucked under the dash probably in about the middle of the firewall. There's also a sneaky inline fuse between the power to the hazard switched tucked away back there.
Coolerman has an excellent library he makes available.
A color coded version that'll probably help you picture it better is here. Starting with power from your 15a fuse (always check the fuses first) the power goes from fuse > turn flasher > split to turn signal switch & hazard (plus hidden inline fuse) and hazard > hazard flasher. So if your turn signals work but your hazards don't, start there and work your way down the line.
maa
You guys on this forum are the best. Thank you very much. I have the diagram you note, but received conflicting advice from a vendor.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
that's why you should seek out a Factory Trained SUPPORTING VENDOR ,
then this is the only correct by the microfiche and FSM consultation remarks you will / would have received ...
by the book ...
1 flasher .......
simple eazy peezy
please review the link below for some further solid tech and info etc ...
