Transmission to Transfer Case Bypass Hose (3 Viewers)
Well, I bought this off @shipmag (transmission / transfer case bypass hose) a few years ago.... I decided today was a great day to install it!!
Edit: I did this back in December, but failed to post it here!!
Thank you @shipmag, that is a great piece of work!
Changed transmission and transfer case oil while i was under the truck.
Transmission oil looked perfect.... transfer case oil looked its age.
5 quarts 90wt did the trick, enough for both.
In the next week or so I will be ordering some more hoses. I do have both sizes in stock now.
If you need a size other than the stock sizes of 12.75” and 17.5” Center of Banjo bolt to center of Banjo Bolt, now would be a good time to order. If you order a non standard size alone my vendor charges almost double. If you have a non stock set up and want these teflon heat resistant hoses with a Stainless Steel braided outer sleeve please do it with this order.
PM me if your interested.
Use a rope or electric extension cord so its stays rigid. Measure center of plug to center of plug. The standard for Toyota plugs on transmission and transfer case is M18x1.5. If yours is a pipe thread youll have to get an adapter as banjo bolts are not made in pipe threads because of the taper of the thread. Ebay has the 1/2 pipe to M18x1.5 adaptors.
Not sure if a PO retapped your plug holes? Hold a straight edge to the side of your plug if its has an angle its pipe.
PM if you have questions. Ive seen a lot of different things PO’s have done and can help you figure a solution.
Ive sold over 400 hoses to cruiser heads. Yep replacing seal is the fix. But did the guy rebuilding your case put the case back together with grooves in the shaft from where the seal rides? The hose is just cheap insurance and the stainless steel braided hose resist the heat from the exhaust pipe that runs close to the hose.
I only have one 12.75" hose in stock. I have several 17.5" hoses left. I have an ordered placed for more the problem is with the virus the fittings are on back order. I have no idea when the new hoses will be delivered.
Thanks
Shipmag
Hagler Technology LLC
I received my Shift Plate and Bypass Hose yesterday. These are outstanding, quality, and beautiful pieces of artwork. I can't wait to get these installed.
I've got one 17.5" hose and 3 12.27" hoses. I share this as in the next couple weeks I will be ordering more hoses. If you need a different size hose now is the time to measure and let me get that special hose ordered for you. My vendor has a minimum order so the only time I can get an odd size is when I place a sock order. Measure fill plug to fill plug. Best to use a heavy electrical cord so you get a more accurate measure. Stock fittings are M18x1. I can not get them made using pipe threads as they don't tighten correctly. We would have to make a pipe to metric straight thread. Sometimes I can find them on amazon or eBay.
