2fpower
- Thread starter
- #21
could you go bigger? 1/2" pipe?? or similar
locktite was making a product to make threads in a hole a couple years ago, not sure if it is still around, it had to do with an epoxy and a release agent on you bolt/plug
FYI- searched this down- in case anyone else goes down this rabbit hole.
3/4 - 16 uses a .6875 drill bit - 11/16
m18x1.5 uses a .6496 drill bit (16.5mm)
I am assuming the .04 inch is not enough to get a good set of threads for this.
So, to upsize, I think my only option is the m20x1.5 used on Subaru drainplugs. Amazon even has the 18.5mm drill bit needed and tap. $55 for drill bit, tap, and new plug.
Again, time sert seems best, but out of my price range.
Only issue I see is that it is hard to tell if there is enough flat surface for the new plug to seal on.
