Cruiserdrew
On the way there
This is really awesome Land Cruiser geek. I've got 2 old ones in my 40 I'm going to dig out and compare ##.
Thanks Treeroot.
Thanks Treeroot.
Pictures for Bill
Ige - Nuclearlemon - RK30 91100
The little baby screw on the crank appears to be correct. The crank handle marked STO should also be the correct one for an RK30 jack (pre 1963)
I believe the STO with the 2 is correct for an RK30. The STO without a 2 is ???
picture of the small screw and a good example of a well used jack
Doing some research (what I do on Sundays) I found a 4L,4G, and 5I with the decal still in place. I can confirm that the decal is the same as the Hilux. The sticker is orientated so that it faces the crank. Shane has reproductions of the '77-'78 decals. Now all we need is to find a good 72-76 one and see if Shane can make those for us.
May of 1976 FJ40 with original jack marked 5I
From left to right
09110-35011 - Variant E
1977-78 FJ40/45/55 Screw Drive: Cross-Head Neck Flange: Wide
Neck Screw: Perpendicular Marked: TOYOTA MOTOR
09111-35060 - Toyota Hilux
09110-35011 - Variant D
1972-76 FJ40/45/55 Screw Drive: Cross-Head Neck Flange: Narrow
09110-35070 - Toyota Hilux
09110-35040 - Toyota Hilux – Toyota Motor variant.
09110-35011 - Variant C
1969-70 FJ40/45/55 Screw Drive: Cross-Head Neck Flange: Narrow
Neck Screw: Perpendicular Marked: TEQ
09110-31020 - Toyota Masterline – The Lift Column Cap is missing on the left one. Interesting that the screws don't match. The 8 has flat head and the 9 had cross head. I would think flat head screws should be correct.
I just now clicked "like" on a few posts in this thread ... but ALL of what you guys have researched on jacks is amazing.
However something here just isn't right...
You hide your age wscBill so I know it's bound to be heading towards triple digits.
But TreerootCO lists an age of just 37.
I just don't think that's possible with the symptoms being exhibited here!
Jacks! Ran out of room... going to need a new shelf. Type A 63/64 and TEQ slotted 31020 missing from the panorama. ...
(A video of you carefully placing them all up there would have been intriguing ... but then I wonder how many would have had the patience to watch it all the way through. )So the threaded and straight parts of the shafts are not supposed to be painted it appears (from all the OE painted ones you have in your collection), but on the gold one you ended up painting it treeroot?
When re-painting a jack for service, what is the best approach? I tried painting a portion of mine and it gummed up. If not painting it, what is the best way to protect the metal? Grease? If the metal is pitted, what is the recourse?
That was isn't painted but cad plated
I was playing in the archives and found a jack I need
The 1958-60? Toyota dump truck had a TEQ hydrolic jack
View attachment 942853 View attachment 942854
