The impression I get is the people that have experienced sway get convinced of the benefit pretty quickly.
Hey you can crack the door or just turn off the ahc on the center console. I elect to turn off the car because I hate the exhaust in my face lol. I will say this is my first go at towing a travel trailer, I have a utility trailer that I have towed even up to 6000lbs but the travel trailer is a much different experience. I will say with this hitch I experienced no sway, zero not even a hint, it just towed great. At one point (now remember first time ever towing a travel trailer) I was going down the flat part of a freeway going 60mph talking to the wife driving with one hand on the steering wheel... she said to me “not to stressed about driving the trailer huh” we both laughed and said the air stream and the propride was a good choice. It was 44 miles to tow it home, we were towing through twisty mountain roads with a speed limit of 65 which everyone goes 75, climbed 2500 feet elevation and during traffic hour on the I-80 freeway, basically an interstate with a whole lot of semi trucks! It towed fantastic, I don’t feel like I need a truck, or a bigger suv or anything else, I think this combination is great.I checked out a couple of Youtube videos and the weight distribution bars seem to be adjustable but not removable. I think I would be quite a ways down the road by the time the Propride or Hensley was hooked up. From what I've seen they're not for me. Impact wrenches and Johnson bars and grease or wax on the stinger is just too complicated for me.
And Rando, couldn't you just crack a door to stop the AHC from kicking in? One of the back doors would do it.
Yes but was it still on it’s way to an even higher temp and cresting stopped the rise as well as let it lower, or was it holding at 237F (not increasing further) and only cooled down when you created?
I’m just trying to figure out if temps would have climbed even more if the hill were longer.
IIRC a propride doesn’t come apart at the ball because it is basically made rigid at that point. It has a 2” square extension that goes directly into the LX hitch receiver. Which means you not only have to put the tongue weight on the jack, you have to have the hitch and load bar misalignment sorted out or it won’t pull out of the receiver. It never occurred to me that the AHS could make this process difficult but it makes sense now that I think through it.
Was that the A/T pan temp or the torque converter temp that hit 237? Pretty normal in the 6 speed for the T/C to crest 240 on a hill climb in 2nd or 3rd. I've only had my pan temp exceed 230 a couple times though - normally when on a hill climb the TC will heat up but I really just watch the pan temp (which is always the same or lower).Once I crested the hill the temps immediately dropped... it does seem quite hot has anyone else experience these temps climbing long steep grades??? I use the OBD Fusion app like @linuxgod uses.
How does it tow?? Well I live in the utah mountains and I towed up a 7% pass called Parleys summit it’s a pretty grueling hill and I often see many trucks pulling trailers pulled over and over heating. I had plenty of power but no way could I keep the speed limit of 65mph! I had to drop it to 3rd gear (I have a 2018 LX570) I made it over the hill going 55mph and my transmission temp was at 237 degrees...
Installed the Redarc brake controller based on the advice in this post. Thank you, it’s stealth, blending in with the interior and worked great.
Zero issues as if nothing was behind me. Didn’t use a WD hitch to see how it would be. Love this car!!! It’s the Swiss Army knife of cars: utility, kid hauler, towing, comfort
I tow a ton. If your trailer ends up over ~2.5-3k lbs I would do a WD given how of a drive. It makes it tow much better, safer, and easier. Make sure the WD is correctly set up. I’ve used the husky round bar for years. It’s considered a more basic older design but I’ve probably got close to 50k miles towing a ~6800lb camper with no issues.I'm thinking of renting (maybe buying and putting up for sale at my destination) an enclosed cargo trailer to drive from CA to AR. I'm planning my move out of the (great, ha) state of California.
Do you think something like a weight distribution hitch is absolutely required for something like that? It's 2,000 miles. Since I'm lifted I think I'll need one of those L connectors to lower the height of the ball hitch for sure, but I wasn't quite sure if I needed to spend $250 (cheap thing on amazon) to $750 on a real weight distribution system. Thoughts?
Husky 30849 Round Bar Weight Distribution Hitch with Sway Control Amazon product ASIN B004RCSKPO
@Rando Kuruza thats probably pan but if you’re using OBD Fusion with the add on Toyota enhanced PID pack both are available to you. I’m sure of that because I have both
I think they show up as AT1 and AT2, but the lower Value temp is always the pan
