If you thought like me that buying a 4x4labs gets you towing hassle free, you will be mistaken.
I had two standard 2" ball mounts - neither fit.
I had a tube extension sent to me by 4x4labs (they made it) the holes did not line up, and I couldn't use it.
I bought a Blue Ox 10" drop ball mount - it did not fit.
So I went to a local metal shop. They ground the Blue Ox down. Now it fit, but the holes did not line up.
Drilled a bigger hole - now everything worked.
I just wished everything just worked after spending so much money on the bumper, and more for installation.
The other things that did not lined up
The jerrican carrier - needed to drill larger holes. Did not fit. You wouldn't think it came from the same shop, but it did.
The frame side holes - you guessed - did not fit. had to elongate them.
Do I like the bumper yes.
Would I buy it again? Yes
But not cart blank. I would make the shop jump thru hoops to make sure everything fit.
I would hold some money back until everything works as it should.
The bumper is great. But it seriously lack attention to details.
And yes, the tire carrier that was sent was the wrong one. But the shop sent me another one overnight and that one fit great.
Finally - I recommend that if you want to tow, plan on getting the Blue Ox. I got the 10" but I recommend getting the 8" or 6"
Rami
Rami
