Waiting on a few deliveries. Getting a few things done prior to test fire # whatever.. after new stuff.. Main cab wiring harness is pretty much installed. Need to finish mount a fuse block. Tested hazards, reverse, brake, turn, park, head, horn, etc.. All getting volts! Cut down / modified a bib park light to clear the 60 power steering box.
Wired the AC idle up into the HVAC harness. Hopefully that will work. Need to plug in the injection harness on the firewall and install some grommets.. Mounted the fuel filter, installed the diagnostic pressure gauges. Shortened the main high pressure feed line from the frame. YouTube taught me to use my soldering iron with a hot knife blade to remove high pressure push lock fittings for reuse.
This truck will have fuel pressure diagnostic gauges on the rail (cold start injector) and the out of the filter. The adapter for the cold start injector gauge is from here
Fuel Pressure Gauge Kit 22RE 3VZ (EFI) - https://www.lceperformance.com/Fuel-Pressure-Gauge-Kit-22RE-3VZ-EFI-p/2019128.htm
The one in the top of the fuel filter is a Russell Banjo Bolt PN 640700 i believe.
Waiting on an AN adapter to run return line from engine to tank. Somewhere in the garage is my return fitting. 3fe's run a 5/16 return, my old adapter was a hodgepodge of fittings so best to get the correct one and not stack reducers.
Transmission oil is here, had to do some research on what an H55f likes. ended up with Mobil Delvac Synthetic 50. Lots of mud info on H55 fluids.. Glad i didn't just toss 90 wt in there like i planned!
Bled the brakes last night, so have pedal again. Waiting on some MIDI style fuse holders from BlueSea to replace the fusilble links in the FJ62 harness. They are old and bulky, didn't like being passed thru the firewall. I know i have a newer oem fuel pulsation dampener on this engine but pretty sure i have not ever replaced the fuel pressure regulator. So will prob order one for safety sake.
Still to come, rewiring the fusible links, building battery cables, trying to get the correct belts. I will try and bleed the clutch tonight. Need to pull the clutch slave to install the boot fork.
