- Joined
- Jan 8, 2006
- Threads
- 265
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
There are a lot of questions about this stuff, so I'll try and clear some things up. First off, stock tire size on most of your trucks is 225/75 R 15.....
Well what does that mean? The 225 is the tread width in millimeters (About 8.86 inches), and the 75 is a ratio, that's right, it's not a measurement of anything, it's a #&%*%*$&$ ratio! Who's dumbass idea that was I don't know. And the 15 is the rim height in inches.
Back on track, 75 is really 75%, so that's 0.75 times the tread width (225 mm) equals the sidewall height, 168.75 mm. Now there are 2 sidewalls (that's 337.5 mm's total, or 13.28 inches) on the way from the ground to the top of the tire, plus the rim. So 15 inches of rim plus 13.28 of sidewalls is 28.28 inches tall.
Now to the gear part, stock gears for our "28 inch tires" (As you see they are technically not 28...) is 4.10, which means your drive shaft turns 4.1 times every time the tire makes one full turn.
The diameter, or rolling distance of our "28 inch" tire is 88.84 inches (Diameter times pi (3.14159) = circumference) Divide that by 4.1 and we travel 21.67 inches for every driveshaft rotation, and that's the number I'll be referring to, because it's directly related to your speedometer (that's the thing you're staring at...)
So now the fun stuff. I'm going to make a good picture for this.... hold on....
