I'm curious how your notching works out. Post up on the results.
Who has a siping tool and is it worth the time to do yourself?
Please video tape this effort as I'm sure it will get a Darwin Award.
Wow! I never thought I'd hear of someone "siping" their tires with a Skilzsaw. Seriously, Just take them into your local tire shop and have them do it for $40-50.
TK
Wet the tire, don't heat the blade.
make sure your girlfriend watches as you try it with the Skil saw, I promise she will want to marry you after you "impress" her with your skills.
A wet tire cuts much easier than does a dry tire. Dramatically easier. Try it, you'll see.Why? By that logic, my boxcutter idea would work great.Wet the tire, don't heat the blade.
X2 on wet tires cutting easier. As a young driver, BTDT on water crossings until I learned that little gem. Wheel speed is not always your friend.A wet tire cuts much easier than does a dry tire. Dramatically easier. Try it, you'll see.
Personally I'd use a carpet knife either set to it's shallowest setting or break/grind the blade to make a shallow cut at it's deepest setting.
that was just playing around.
ill do a beter job on my actual tires.
and i didnt cut my dick off
